I am using the "heading links" feature as described here: https://www.esri.com/arcgis-blog/products/arcgis-storymaps/constituent-engagement/storymaps-heading-links/ to create a sort of within-story map table of contents for a specific piece.
I tested it with one link - it works. I go back in and add the rest of the links. After publishing, the test link now redirects to a new tab with "about:blank#blocked" in the address bar, but the subsequently added links work properly. I went back in and fixed the first link - after publishing it works but the others now redirect.
It appears that something is breaking when publishing the story. I can go in and change all the links simultaneously, but this is a frequently updated storymap, and I would prefer not to have to redo all the links every time we publish an updated version.
