Hello everyone
I am currently trying to work the image analyst extension but keep receiving an error about my 'domain name being invalid' along with 50+ error messages. Has anyone else experienced this and what do you do?
thanks for any help you can give
Andrew
Hi Sandeep
Thank you for your reply. This does seem like a possible reason. Stupid question but what exactly is the 'repo'?
thanks
HI @AndrewEastop,
I checked your error message and it seems that your workstation does not have access to internet or at least to the repo which contains pretrained model backbones. It may be due to firewall at your workplace.
If your issue is still not resolved, I would recommend you to perform this additional installation for disconnected environment https://github.com/Esri/deep-learning-frameworks#additional-installation-for-disconnected-environment .
Sandeep
Thanks Dan. I have been on to them before and they could not find the issue so looks like I am stuffed 😞
Don't know off hand, it might be better to contact Tech Support. Something must be wrong with the input data or its environment especially if you have no other data to test (unassociated with your current project/*.aprx)
Hi Dan,
I am literally just trying to work any of the IA tools for now but every single one I use gives the same error. Very frustrating!
The error is attached as an image to his post
160676: The domain name is invalid.—ArcGIS Pro | Documentation
Note:There is no documented solution at this time.
You might need to elaborate a bit more as to what you are doing.
