Error:
Traceback (most recent call last): File "C:\Python27\ArcGIS10.6\Lib\site-packages\Pythonwin\pywin\framework\scriptutils.py", line 326, in RunScript exec codeObject in __main__.__dict__ File "C:\Users\jstout\Desktop\PY\ESRI1.py", line 37, in <module> server.sendmail(FROM, TO, MESSAGE) File "C:\Python27\ArcGIS10.6\lib\smtplib.py", line 742, in sendmail (code, resp) = self.rcpt(each, rcpt_options) File "C:\Python27\ArcGIS10.6\lib\smtplib.py", line 490, in rcpt return self.getreply() File "C:\Python27\ArcGIS10.6\lib\smtplib.py", line 369, in getreply raise SMTPServerDisconnected("Connection unexpectedly closed") SMTPServerDisconnected: Connection unexpectedly closed
My Code
import arcpy, arceditor, time, smtplib
# Set the workspace
arcpy.env.workspace = r'C:\Users\jstout\AppData\Roaming\ESRI\Desktop10.6\ArcCatalog\EED_FM@SDE.sde'
# Set a variable for the workspace
adminConn = arcpy.env.workspace
# Get a list of connected users.
userList = arcpy.ListUsers(adminConn)
print "User List Finished"
# Get a list of user names of users currently connected and make email addresses
emailList = [user.Name + "@cityofelizabethton.org" for user in arcpy.ListUsers(adminConn)]
print "Email List Finished"
# Take the email list and use it to send an email to connected users.
SERVER = "cityofelizabethton-org.mail.protection.outlook.com"
FROM = "SDE Admin <jstout@cityofelizabethton.org>"
TO = emailList
SUBJECT = "Maintenance is about to be performed"
MSG = "Auto generated Message.\n\rServer maintenance will be performed in 15 minutes. Please log off."
# Prepare actual message
MESSAGE = """\
To: %s
Subject: %s
%s
""" % (FROM, ", ".join(TO), SUBJECT, MSG)
print(MESSAGE)
# Send the mail
server = smtplib.SMTP(SERVER)
server.quit()
print "Email sent"
# Block new connections to the database.
# print("The database is no longer accepting connections")
# arcpy.AcceptConnections(adminConn, False)
# Disconnect all users from the database.
# print("Disconnecting all users")
# arcpy.DisconnectUser(adminConn, "ALL")
# This portion is to call a C# executable to call orphaned version cleanup.
print "Start EED Automated Cleanup"
import os
os.startfile(r"C:\Users\jstout\Desktop\EED_Automated_Cleanup\bin\x86\Debug\AutomatedCleanup.exe")
import sys, string, os, arcgisscripting
import subprocess
subprocess.Popen([r"C:\Users\jstout\Desktop\EED_Automated_Cleanup\bin\x86\Debug\AutomatedCleanup.exe"])
print "Automated Cleanup finished"
# Wait .5 minutes
time.sleep(30)
database = "Database Connections/toolboxDEFAULTVersion.sde"
versions = arcpy.ListVersions(adminConn)
# Print the versions available to the user
for version in versions:
print(version)
print "Version list complete."
# Execute the ReconcileVersions tool.
# Use a list comprehension to get a list of version names where the owner
# is the current user and make sure sde.default is not selected.
print 'Reconcile versions started.'
verList = [ver.name for ver in arcpy.da.ListVersions() if ver.isOwner
== True and ver.name.lower() != 'sde.EFAULT']
arcpy.ReconcileVersions_management(adminConn, "ALL_VERSIONS", "SDE.DEFAULT", "", "LOCK_ACQUIRED", "NO_ABORT", "BY_OBJECT", "FAVOR_TARGET_VERSION", "POST","DELETE_VERSION")
# Write messages to a Text File
txtFile = open("c:\\temp\\GPMessages.txt","w")
txtFile.write (arcpy.GetMessages())
txtFile.close()
print ('see error log at "c:\temp\GPMessages.txt"')
print'Reconciling Complete'
# Run the compress tool.
print("Running compress")
arcpy.Compress_management(adminConn)
# Use a connection file to create the connection
print "Check state ID"
egdb = r'C:\Users\jstout\AppData\Roaming\ESRI\Desktop10.6\ArcCatalog\EED_FM@SDE.sde'
egdb_conn = arcpy.ArcSDESQLExecute(egdb)
table_name = 'EED_FM.sde.sde_States'
field_name = 'state_id'
sql = '''
SELECT {0}, COUNT({0}) AS f_count FROM {1}
GROUP BY {0}
ORDER BY f_count DESC
'''.format(field_name, table_name)
egdb_return = egdb_conn.execute(sql)
for i in egdb_return:
print('{}: {}'.format(*i))
print "State count complete"
# Allow the database to begin accepting connections again
# arcpy.AcceptConnections(adminConn, True)
# print "allow connections to database"
# Update statistics and indexes for the system tables
# Note: to use the "SYSTEM" option the user must be an geodatabase or database administrator.
# Rebuild indexes on the system tables
print("Rebuilding indexes on the system tables")
arcpy.RebuildIndexes_management(adminConn, "SYSTEM")
# Update statistics on the system tables
print("Updating statistics on the system tables")
arcpy.AnalyzeDatasets_management(adminConn, "SYSTEM")
print("Finished.")
