I'm looking for guidance with how to properly extend a class with respect to its constructor. All of this is in typescript. I'm extending the Graphic class. Normally the graphics class take a GraphicProperties object. I'm my class I had new properties. I would like to change the constructor from
constructor(properties?: any) { ... }
to
constructor(properties?: SegmentProperties) { ... }
Also, is it possible to define the type of properties without initializing them in the constructor?
My full code is below:
import Graphic from "@arcgis/core/Graphic";
import Polyline from "@arcgis/core/geometry/Polyline";
import LineSymbol3D from "@arcgis/core/symbols/LineSymbol3D";
import LineSymbol3DLayer from "@arcgis/core/symbols/LineSymbol3DLayer";
import { subclass, property } from "@arcgis/core/core/accessorSupport/decorators";
import GraphicsLayer from "@arcgis/core/layers/GraphicsLayer";
import Point from "@arcgis/core/geometry/Point";
import * as watchUtils from "@arcgis/core/core/watchUtils";
@subclass("esri.core.Graphic.SegmentGraphic")
export class SegmentGraphic extends Graphic{
@property()
startPoint: Graphic;
@property()
endPoint: Graphic;
@property({
readOnly: true
get length(): number {
return 10;
super(properties);
this.startPoint = properties.startPoint;
this.endPoint = properties.endPoint;
this.updatePolyline()
this.symbol = new LineSymbol3D({
symbolLayers: [
new LineSymbol3DLayer({
material: {
color: "red"
this.registerWatchUtil(this.startPoint);
this.registerWatchUtil(this.endPoint);
private updatePolyline() {
let polyline = new Polyline({spatialReference: this.startPoint.geometry.spatialReference});
polyline.addPath([this.startPoint.geometry as Point, this.endPoint.geometry as Point]);
this.geometry = polyline
private registerWatchUtil(point: Graphic){
watchUtils.when(point, "geometry", (geometry) => {
