I have a simple grid theme survey, using w2. The first two fields align perfectly, but the second two have a vertical offset in the entry portion. All 4 fields have w1 in the appearance column, although 'Ranger Name' is w1 autocomplete. I've attached a screenshot of the survey as it displays. Any ideas on how I can get these aligned would be appreciated.
I believe they will be addressing this in the next S123 release by aligning all those fields top? I am sure someone else can confirm that though.
Short answer is, there is nothing you can do about that at this time (at least that I am aware of).
That is good news! Thanks 🙂
@MichelleHawks1Not sure if you follow the beta, but I knew I saw this mentioned somewhere: Improvements to Grid-Theme cell content alignment (select_one and select_multiple choice lists are now top aligned).
This will be added in the next version of S123, which should be soon.
Thank you. It's not what I wanted to hear, but is very good to know when to stop banging my head against the wall. I appreciate your response!
