Hi all,
Offline map areas were defined in the Field Maps desktop app. I the owner of the data can successfully download the offline these. No other group members can. We tried defining the offline areas in AGOL - same result. The map works fine when no offline areas are created. If enabled for offline users can create their own offline areas no problem. It works perfectly when not enabled for offline use too.
There are three layers in the web map. A point layer - 421 points with 5 attributes. This is non editable layer, it is a reference layer for location information.Two empty feature classes created in Pro with a number of attributes and coded value domains exported as web layers. Configured in AGOL. Smart form configured in Field Maps app.
I can't think of anything else to try really. Perhaps the solution is to let field workers create their own offline areas. It is however quite a big coastal survey some of the monitoring sites are 28km apart. It just adds to the workload of the field workers if they have to create the offline map areas too so my preference would be to fix the issue.
Any ideas or suggestions would be great!
Thanks million.
Peter
