I'm having a hard time figuring how to import "view" from "@arcgis/core/views/View" to use the `view.whenLayerview()` function` while trying to refactor the code to use WebPack.
I am getting the following error:
uncaught TypeError: _arcgis_core_views_View__WEBPACK_IMPORTED_MODULE_0__.whenLayerView is not a function
I have also tried using "import * as view from @arcgis/core.views/View" but that didn't help.
Thanks for your replies !
Thanks for your replies!
I found the problem, my error was trying to import view from @arcgis/core module while the view needed for the whenLayerView is the reference to the MapView. importing the view from where mapview is defined instead works.
Tagging onto Ben's comment, add this code to that sample and it should just work:
map.add(layer); view.whenLayerView(layer).then((layerView) => { console.log(layerView); }) .catch((error) => { console.error(error); });
I suggest using this sample as a starting point for your app:
https://github.com/Esri/jsapi-resources/tree/master/esm-samples/webpack
If your issue is still reproducible in that sample we can take a closer look.
