I am most positive that I am not the sharpest tool in the shed. With that said, hopefully someone can get me over this seemingly easy yet difficult bump. I am new to working with the Utility Network Extension for Enterprise. It is loaded into the organizational Portal and the both the Water and Sewer data management for enterprise have been activiated.....I am starting with a small area of our water distribution system. The existing data is NOT in a geometric Network and for the most part are just lines and points in respective feature classes.
So, through some on-line ESRI produced video, I am trying work through the data loading tools as described in said video(s). using the python package manager, I have cloned the default and add the dltsolution and the r-cdltools packages to the clone. Exited and restarted ArcPro, as indicated in the video and instructions from ArcPro. Upon restarting ArcPro and looking for these "new tool" in the geoprocessing window, the geoprocessing Cache begins to rebuild. then this process crashed with a message that the dltsolutions package cannot be found in the clone environment. (note: the pathway to the clone environment is different from the default path, but this is what is presented b ArcGIS Pro.
Bottom line is I need help in loading my existing data into the new utility network. Any advice, suggestions, or directions would be most appreciated.
James Armstrong - jamesa@spatial-relationships.com
