I am having troubles getting my repeat answers to show up when i go to edit through the inbox. My workflow requires that i have a survey with a single repeat that i want one group to complete. A second group will edit the repeat answers if necessary through the inbox so they need to be able to see what the previous answers were. I set allowUpdates=true in the bind::esri:parameters column for the begin repeat row and republished the survey but this did nothing. When i open the sent survey through the inbox it doesn't pull in any of the previous answers. Am i missing something??? I have also tried adding quote "" marks around the allowUpdates=true but this has not worked either.
Josh
You need to add the query parameter. See https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm#ESRI_SECTION1_80CFFC9C38654DC293D4F36C5376C62E
That worked!
