I have been working with various ways to Export map tiles from a base map. I have used the Export Tile Cache Example that is provided and as well I have used the Tile Package Kreator by Esri Labs. The Tile Package Kreator is a great and simple utility to use. However, most of these Export options have a limitation on the size of file that can be created/exported (1GB, for Kreator). That is fine until one also needs a high zoom availability... I have not used ArcGIS Pro, but is there any way to Export a map without the size limitations? I understand that the file can be quite large. Just need to know if it is doable.
