I'm having a problem exporting a map from ArcGIS Pro v2.8.0. I have four raster layers overlaid with each other, one land cover layer and three copies of ESRI's Terrain:Hillshade raster that's available from the Living Atlas Portal that I accessed through the Catalog. Each of the Terrain:Hillshade layers have different Appearance settings with varying Transparency levels and Layer Blend options. It looks great in a Layout, but when I try exporting it, the output map is missing sections of the three Terrain layers (see image 'LandCover_Test.jpg').
I've tried changing a number variables one at a time in the Export Layout pane without any luck. The only thing that seems to work is if I adjust the scale, i.e. zoom into the map layer (see image 'LandCover_TestZoom.jpg'). Hoping to be able to export this map at the scale that I originally intended!
Thank you.
