Hello Mind Hive!
I'm using Field Maps to collect forestry data over some large (~7,500) acres and have to use offline mode. There are four team members using Android tables and I am using an iPad. After the field crew collects their data and syncs the data I sync my iPad to do field checks. The problem is that not all of the fields for points are downloaded to my iPad after the sync. All of the attachments and only a handful of the fields are populated when I look at the data for a point when I select it in Field Maps. The data are on ArcGIS Online - I can seen them in the ArcGIS Online Map Viewer - but are not downloaded during the sync. The field crew using Android tablets is having the same issue.
Has anyone else run into this issue and, if you have, how did you resolve it?
TIA!
