Hi All,
I have looked for previously, and seen others ask for the ability to pull in the values for objectid, Creator, CreationDate, Editor and EditDate from an Inbox survey.
I ran across a post recently (can't find it again), but it pointed me to using a note field with the name set to whichever field you want to pull and in, a label and the bind::esri:fieldType set to null. This works great, I get all the values pulled into my survey to use, but not edit... Perfect. (Connect V3.12.232)
The issue I now have is that these field no longer appear to be usable in the Feature Report for the survey. When I generate a sample template for the survey, the Creator is in the template. When I try try to upload the template I get "Error: An error occurred when checking the report template. Failed to parse ${Creator} since field name or parameter Creator cannot be found in the current parsing scope."
I have used all of the mentioned fields in the reports previously...
Any direction helpful!
Thanks, Larry
