Does anyone know when sub-groups/Inception layers will be supported in Map viewer?
In this blog post under 'What comes next', it says that upcoming capabilities include "Enabling you to create groups of Group Layers (Inception layers)"
(https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/try-out-layer-groups-with-map-viewer-beta/)
If this feature is not due soon, does anyone know of a workaround to include sub-groups within groups in Map viewer?
Many thanks.
You can open the current web map in ArcGIS Pro and add group layers and then save the web map
https://pro.arcgis.com/en/pro-app/latest/get-started/share-a-webmap.htm#ESRI_SECTION1_B484CE84983E470292B8C8C7355A8946
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/save-a-web-map.htm
That's great, thanks for the link Russell.
Yup 10.9.1 Will have New Map Viewer included out of beta: https://www.esri.com/arcgis-blog/products/announcements/announcements/whats-new-in-arcgis-enterprise-10-9-1/
The version of Pro I believe needs to be at least 2.7
Hi @RussRoberts
Can I just check that you can definitely create groups of layers in the webmap that have been published to Portal in ArcPro in Enterprise 10.9.1? I just don't see any reference to creating a group of layers in the links.
I'm trying to update a webmap I have for users that has groups of layers published as a map image layer. However I'm trying to update it by adding in some hosted feature layers within the groups, but these don't appear once published. So I'm back to not being able to create the groups.
I'll push to upgrade to Enterprise 10.9.1 if this resolves it.
Rachel
Has anyone tried this successfully?
I've just brought in my webmap to ArcPro, created a group then saved the web map. But when I view the web map in Portal it has ungrouped the layers.
Hi. Thanks for the reply. Is there no way of accomplishing this with the content I already have published in AGOL? Or is the only option to republish all my required layers (in their groups and sub-groups) from Pro?
This is currently not planned for an upcoming release but you and publish group layers with sub group layers from ArcGIS Pro today.
