Just wondering if there has been any serious consideration to allow MultiPoint editing in ArcGIS Online and Collector. Many of our clients that use ArcGIS Online and Collector (starting to use Field Maps) have asked about this capability for some time and just hoping Esri is considering implementing this enhancement in the near future. Any feedback would be appreciated. Thank you.
Editing multi-part features (including multipoint) is now supported in the new ArcGIS Web Editor. Check it out!
Well 'supported' is a strong term. I can't even save a map once I have a multipoint layer added to the map aside from the first time.
When trying to change a popup configuration or even adding additional layers or slightly changing some sort of symbology, I then can't save the map as I receive an error saying 'layer cannot be added to the map'. It's no coincidence that that specific layer contains multipoints. When I converted to a single part point, republished and did the same workflow I was successful. As I said 'supported' is a strong term.
It would be really helpful if you could actually save a map thereafter.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
