Hi! So I'm currently working on my Bachelor Thesis and I used the Line Density Tool (In ArcGIS Pro) to measure the density of Bikelanes in squaremeters. However in the Paper i based my method on they used "Math tools" to converse the given output raster from square meters to meters of Bikelane per square meter. I've been breaking my head about this and I just can't find the formula to calculate it like that.Which Math Tool can I use to calculate that and what would the formula be? To Anybody who knows how that works thanks in advanced and you'll be my rescue.Thanks! 🙂
Agreed with Daniel, you need to read https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/how-line-density-works.htm
The line density is to calculate the length of some lines in a certain area (it is a circle now). So the unit is the length of lines per area, which could be meter/square meter or inch/square meter or meter/square inch. I guess if you see the unit is square meter only, it might represent the count of lines per area. Then, they calculated the length of each line in meter.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/how-line-density-works.htmYou'd really need to consider you search radius, and work backwards from the area of the circle of that radius and the length of the bike lanes within it.
is this metres of bike lane per sq metre of a larger aggregation area? If you have larger defined aggregation areas you may want to do something like a Spatial Join https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/spatial-join.htm and summing the length attribute in the field mapping, or https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/tabulate-intersection.htm
Thanks for the answers! I think I was just confused by the methodology in the papers.
Hi! I'm facing the same issue currently while working on my master thesis. Even with the given answers I don't really understand what needs to be done here. I calculated the line density with the line density tool and used a 100x100m Output cell size as well as 250m search radius and Square Meters as Area units. So far so good. Now I get values from 0,001-0,017 and don't really understand them. Which Math tool did you use to solve the problem you had? The papers I read had values from 0-1350 or higher but that can't be m/m² of cycleways..
I appreciate your help to rescue me too! 🙂
