Hi
I use the standard print widget https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Print.html ) In combination with a custom print service and a custom MXD print template.
When I un-tick the "Include legend" option to false/unselected, I still get legend items for all operational layers submitted as part of the JSON Export Web Map request.
I can see that the list of legend options array is empty when unticked:
"legendOptions": { "operationalLayers": [] }
Compared to when selected/true:
"legendOptions": {
"operationalLayers": [{
"id": "customLayers",
"subLayerIds": [8]
"id": "colorsLayer",
"subLayerIds": [0]
"id": "labelLayers",
"subLayerIds": [1]
The PDF generated from my custom template make no difference though - all the operational layers appear in the legend when that setting is ticked or not.
If I unselect the "Add a new item to the legend when a new layer is added to the map", then nothing appear on the legend. - It seems like that setting is used for all layers added, but only when no specific legend information are summited to the print services. (When I experiment by submitting JSON manually and ask for legend content for a subset of the operational layers, then only those layers appear in the legend.)
Is it possible to NOT have a legend from the standard print widget?
I attached some screenshots for context
