Good Morning All,
I am working with a set of parcel data that I obtained from a local government. I downloaded the data and unzipped the file so it could be used in ArcPro. Upon adding the data into my map, a certain amount of the data like parcel numbers seems to be corrupted and I end up with a bunch of parcels with the same ID number, when each parcel should have its own ID number. I am not sure if it is an ESRI issue because the raw data seems to be fine in excel but once I look at it side by side, excel and the attribute table, the attribute table repeats the same parcel ID several thousand times.
If anybody has any tips on this I would greatly appreciate the help. I have tried to export the table from GIS back to CSV and still getting the repeating data issue. I have also tried breaking the data into increments of 50K and use table to excel tool and the problem still persists.
