Hi.
I'm trying to create a Dashboard using the arcgis.apps.dashboard library, and I've got a problem creating charts. I've succeeded in creating a empty chart and adding it to a new dashboard, but as soon as I try to add a valuefield I get an exception. The chart is using groupByValues, so I need to add a field using the function add_value_field(). I pass the fieldname through this function like this:
chart = SerialChart(item = webmap,
layer=0,
name="Test Chart",
title = "Test Title",
categories_from = "groupByValues")
chart.data.add_value_field("PriKlasse")
Then I get this exception:
~\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone1\lib\site-packages\arcgis\apps\dashboard\_serialchart\_serial_chart.py in _field_type(self, field_name)
1046
1047 def _field_type(self, field_name):
-> 1048 f_type = self._item.tables[0].query().sdf[field_name].dtype
1049 return f_type
1050
IndexError: list index out of range
The error seems to be the same as described in this post: https://community.esri.com/t5/arcgis-api-for-python-questions/creating-dashboard-elements-with-geojson/m-p/1024505
