I have found that when loading an mmpk, the MinScale for the map is derived from the most restrictive layer. For example, if I have a map with 3 layers, with MinScales: 1:5,000, 1:24,000, and 1:0 (no scale restrictions), then the map gets a MinScale of 1:5,000. So then the MapView locks the user from zooming out beyond 1:5,000. MinScale indicates how far you can 'zoom out' before the layer disappears, so I would expect that in this case the MinScale of the map should be 0 (no scale restriction), since there is at least one layer visible at all scale ranges. I'm just guessing, but it appears that perhaps the Runtime is perhaps attempting to prevent the user from zooming out to a scale where no layer is visible? But if so, the logic seems to have been inverted. It works as expected for a webmap.
Here is an mmpk that can be used to test:
https://latitudegeo.maps.arcgis.com/home/item.html?id=9c03b622bff54de9a6fedae8a99df0f0
It contains 3 layers with the minscales mentioned above, 5000, 24000, and 0. The Map comes out with a MinScale of 5000.
