Looking for a little guidance on irregular stops for the TimeSlider widget. I have a point feature layer with a start_time field. Normally I use the "instant" mode and add the stops manually by adding the new date/time instance to the end of the array. For example stops: { dates: [ new Date(2021, 3, 7, 5, 25, 0), new Date(2021, 3, 7, 9, 15, 0), new Date(2021, 3, 7, 15,10, 0)) ] }.
This works fine and meets the need, but as updates to the layer are frequent I don't have the time to consistently add the new dates as they occur. Is there a method that would allow me to add each date in the field as a stop in the TimeSlider widget without having to add it manually? Each timestamp in the layer must be viewed on the slider, though multiple points may share the exact same timestamp.
Thanks!
