Hey,
I am hoping someone can help. I am trying to automate the publication of 50 different readerfiles. So here is my set up. My Mxds read from an Admin_Geodatabase and I regularly override those shapefiles with new shapefiles when I get them or updating existing shapefiles. The MXDs will automatically drawn in the new shapefile but then I have to go to each MXD and republish the reader maps. Is there any way to write a script??So I don't think there is a function - ExportPMF so I was trying to use it in model builder but I wasn't sure if you are able to use extensions or even sure how to add them to the model builder. Steps: Open MxdClick Publish MapParameters for File location and file nameClick okClick yes for overrideclose Mxd Repeat for next 49 MxdsWould anyone be able to help me with this?
Is there a way to create an automated Readerfile publish? I have a good understand what order the script needs to be but I have little to no scripting background. I looked online to see if their was like ExportPMF function in the arcpy library and their isn't. Man that would make my life easy. So now, I am trying from the basics. Open Map, Open Publisher ExtensionSelect Publish Map
file path variable =G:\APN Maps
File name -Fresno_County.pmf
If override select yes.
Wait 2 minutes.
Close Map.
That is correct for online publishing. I already know those scripts. I need it for creating a PMF for readers.
Well, you moved your response to his question, but the question itself isn't here
Hello @mmedinamilam152
I believe you can automate an ArcGIS Publisher workflow using python, so I'm going to move this question to the Python Questions board where you might find an answer.
Additional Info:
ArcGIS Publisher | Share & Distribute Digital Maps & Data
An overview of Publisher - ArcMap | Documentation
Publishing a map service with Python - ArcMap | Documentation
