Hi all,
I've run into a problem that has me stumped. A while back I made a custom print template and published it to ArcGIS Server, and it worked great for a while, but all of a sudden I can't print some secured services that reside on the same ArcGIS Server instance as the print tool. The only clue I'm getting from my server logs is the message that Export Web Task is failing to create a layer from the service in question. In my latest example, I had a service that's shared with my organization throw this exception, but it began working once that same map service was made public. Again, everything is on the same server, and I'm stumped as to why it's now not working as expected. Thoughts?
Thank you!
Ben
