I recently came across something I found a bit confusing.
In field calculator if say I want to auto-increment a field, I can create a simple function to add 1 to a variable starting at 0, then return that value - but I have to set that variable as a global:
counter = 0
def increment():
global counter
counter += 1
return counterIf however I want to keep appending to a list such as to find duplicate values - How To: Identify duplicate field values in ArcGIS 10.x (esri.com)
The list is retained in a global scope (I guess?)
uniqueList = []
def isDuplicate(inValue):
if inValue in uniqueList:
return 1
else:
uniqueList.append(inValue)
return 0My thinking was always that the pre-logic code block and function is executed in isolation on a per-row basis unless a global variable is set - which then (in my mind) isolates that variable from recreation each time.
Do I need to do some back-to-basics reading on local and global scope, or is this just an esri quirk?
I don't have a computer science background and am self-taught (as most probably are) and still learning every day, but would appreciate if someone could explain it, since it's bugging me.
Cheers.
