Is it possible to use the API publish() method in a stand alone script? The following script runs from a Pro Notebook using version 1.8.4 of the API. But, if I run the same script as a stand alone I get a JSONDecodeError. I'm trying to publish a CSV to Enterprise Portal. When I put it in a try and except block it catches the error, but nothing publishes
Script that I'm running in Pro:
from arcgis.gis import GIS
import os
gis_dest = GIS('Home',verify_cert=False, trust_env=True)
# data
fp = r'C:\data.csv' #path to CSV
# content manager
cm = gis_dest.content
# 1. add
item = cm.add(item_properties={
'type' : 'CSV',
'title' : 'c19_Vaccine_Current_test3',
'tags' : 'tags',
'typeKeywords' : "CSV"
data=fp)
# 2. analyze
analyze_csv = cm.analyze(item=item, file_type='csv')
pp = analyze_csv['publishParameters']
# 3. Modify the publish parameters then publish
# For tables ensure the `locationType` is None
pp['locationType'] = 'none'
pitem = item.publish(publish_parameters=pp, file_type='csv')
Line 17 it's referring to is this line:
data=fp)
File "pathto\test.py", line 17, in <module>
data=fp)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py", line 4265, in add
owner_name, folder)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 355, in add_item
resp = self.con.post(path, postdata, files)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 720, in post
force_bytes=kwargs.pop('force_bytes', False))
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 504, in _handle_response
data = resp.json()
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\requests\models.py", line 900, in json
return complexjson.loads(self.text, **kwargs)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\json\__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
