So I set up a survey recently and had all of the rules set the way I wanted and to go to the next question/s I was wanting if that condition was met. They were from the drop down option which is supported. Well I returned to the survey the next day and all of my rules changed to different locations/questions so I went through and reset everything and would save after every submission and again as soon as I leave that survey and return to it all off the rules are broken and going to the wrong questions or in some cases have completely disappeared. Anybody know why this might be?
Hi had the same issue, random changing the rules. You can check it after publishing by refreshing your browser. My solution was to use the Survey123 Connect app and changing it to the rules I want. So I end up using the webdesigner as "experimenting" and when I know how and what i hav eto change to Connect.
Hello @CodyClemenson,
Do any of your choices have a greater than or less than symbol in them that you are using in your rules?
Thank you,
Zach
