Hi the Runtime team,
I would like to report the following bug
OpenStreetMap basemap or OpenStreetMap vector layer (custom style) causes mobile application to crash when set at higher scale.
The cause of the crash was analyzed by the AppStudio team and the crash is at the Runtime level.
To reproduce:
- Create a web map with an OSM basemap in ArcGIS Online.
- Use the MapViewer AppStudio template, set the APP property Map Query in Gallery id:YourWebMapItem
- Build the APP (using the cloud based build)
- Install and run the APP on your mobile.
- Alternatively, you can use the AppStudio player on your mobile
- Try multiple zoom in, pan around, etc.
- The App will crash
Reproducible on Android 10.0
- Apk built AppStudio Cloud based build
- AppStudio Framework : 4.4.77
- Runtime SDK 100.8
- Or use AppStudio Player 5.0.9
- AppStudio Framework : 5.0.126
- Runtime SDK 100.10.0.3002
Please let me know if it is a not issue and there is a work around.
Looking forward to hearing from you.
Thank you
Frédéric
