Hey guys!
I've encountered a problem that Elevation Profile widget version 3.35 is being destroyed incorrectly. I've tested it in different situations (even in the sample for this widget), and in all cases during the process of destroying it throws this type error.
Uncaught TypeError: Cannot set property 'innerHTML' of null. svg.js:formatted:278
at Object.destroy (svg.js:formatted:278)
at Object.m ((index):201)
at Object.destroy (svg.js:formatted:1282)
at Object.destroy (Chart.js:5)
at Object.destroy (ProfileChart.js:31)
at Object.advice ((index):122)
at Object.e [as destroy] ((index):121)
at Object.destroy (ElevationProfile.js:22)
And here is the source code that throws an error directly (I've commented the desired line).
t.Surface = w("dojox.gfx.shape.Surface", null, {
constructor: function() {
this._parent = this.rawNode = null;
this._nodes = [];
this._events = []
destroy: function() {
p.forEach(this._nodes, n.destroy);
this._nodes = [];
p.forEach(this._events, function(b) {
b && b.remove()
this._events = [];
if (u("ie"))
for (; this._parent.lastChild; )
n.destroy(this._parent.lastChild);
else
this._parent.innerHTML = ""; // it crashes here
this._parent = null
getEventSource: function() {
return this.rawNode
_getRealMatrix: function() {
return null
isLoaded: !0,
onLoad: function(b) {},
whenLoaded: function(b, k) {
var l = x.hitch(b, k);
if (this.isLoaded)
l(this);
else
f.once(this, "load", function(e) {
l(e)
}); Has anyone else encountered the problem?
