Hey all,
So I've noticed increased sluggishness with multiple feature classes in specific datasets within our SDE database regarding being drawn on screen. If I export/import them into another dataset, they will load quick and efficiently. It would be nice to avoid this as the overall solution as I would have to go through and fix a lot that links back to them via the existing pathways.
The one common denominator I've found is the Domain Resolution and Tolerance tab will have some crazy figures on the slow loading dataset offenders. Is there ANYWAY to correct this without going through and starting over with new datasets? Is that even a possibility for a cause of my sluggishness problem to begin with? They were not always this way, which leads me to hope that since they were changed, they can be changed again(?). We're currently in the middle of a billing system upgrade that touches our GIS and it would not surprise me if something was messed with. I've gone through and compressed the database already, no dice.
That being said, please, talk to me like I'm 8 years old as I'm not a specifically formally-educated GIS guru and you're not going to hurt my ego hahaha See attached for some screenshots of good and bad dataset Domain Resolution and Tolerance tabs. Thanks in advance if you can offer any advice on this!
