we have 10.3.1 our field guys are using collector for hydrant flushing program. they are editing directly to our sde default versioned database. for some reason when i do our nightly compression of the database their edits are not showing up in the base tables. they are staying in the delta tables. this problem seems to have just started. it was working last week. any ideas what might be causing this?
It sounds like there is a blocking version in the GDB that has not been Reconciled/Posted yet.
https://community.esri.com/groups/geodatabase?sr=search&searchId=8cebf85a-f755-4229-8734-4113903f4128&searchIndex=0
George
Thanks for the reply. We don't have any versions created from our default. So not sure what would need to be reconciled and posted. We do have multiple one way replications that are childs of our default. would that cause it to behave like this?
That may be possible. Here is a white paper talking about replicas and the compress. I know it is old, but still applies.
http://downloads.esri.com/support/whitepapers/ao_/J9842_GDB_Compress_With_Replicas.pdf
Update: What changed between last week (when the compress move the edits to the base table) and now?
So i figured out that i had to stop the map services that are hitting our default database. Just disconnecting them using the admin window in catalog was not enough.
