Hi All,
I have a water utility network setup in an enterprise geodatabase.
I would like to know if it is possible to combine the output of 2 traces into a single diagram.
For instance, I am running a shortest pat trace between 2 points in the network. The first trace finds the shortest path and I create a network diagram from that selection. I then add those selected features as barriers for a second shortest path trace that I run so I can find an alternative "diverse" path in the network. I create a network diagram from that trace.
Now I would like to combine those 2 outputs into a single diagram, or have some mechanism to run the 2 traces and select all features to create a single unified diagram.
Does anyone know if this is possible?
Many thanks.
