I am trying to rotate points and the problem is that when you select the point and click the rotate tool, the center of the tool highlights yellow and it obscures the point such that i can no longer see it to know how much I need to rotate it. For example, I use valve symbols and arrow symbols for some of my points and I can't see the orientation of it when it's highlighted yellow. I have to rotate it a bit and deselect it to see how far and then tweak it again.
Any way to turn off or change that highlight color?
Thank you,
Shawn
