Hi
I use this code to export to SHP but if the WhereClause is null it still make empty SHP file
How can I stop the export if pQFilter.WhereClause is notthing
Dim pDoc As IMxDocument
Dim pMap As IMap
Dim pFLayer As IFeatureLayer
Dim pFc As IFeatureClass
Dim pINFeatureClassName As IFeatureClassName
Dim pDataset As IDataset
Dim pInDsName As IDatasetName
Dim pFSel As IFeatureSelection
Dim pSelSet As ISelectionSet
Dim pFeatureClassName As IFeatureClassName
Dim pOutDatasetName As IDatasetName
Dim pWorkspaceName As IWorkspaceName
Dim pExportOp As ESRI.ArcGIS.GeoDatabaseUI.IExportOperation
pDoc = My.ArcMap.Document
pMap = pDoc.FocusMap
pFLayer = pMap.Layer(ep_layer)
pFc = pFLayer.FeatureClass
pDataset = pFc
pINFeatureClassName = pDataset.FullName
pInDsName = pINFeatureClassName
Dim pQFilter As IQueryFilter
pQFilter = New QueryFilter
pQFilter.WhereClause = "TYPE '" & ep_query & "'"
pFSel = pFLayer
pSelSet = pFSel.SelectionSet
If pSelSet.Count = 0 Then
Exit Sub
End If
If pFc.FeatureCount(pQFilter) <= 1 Then
Exit Sub
ElseIf pFc.FeatureCount(pQFilter) >= 1 Then
pFeatureClassName = New FeatureClassName
pOutDatasetName = pFeatureClassName
pOutDatasetName.Name = ep_name
pWorkspaceName = New WorkspaceName
pWorkspaceName.PathName = path.txt
pWorkspaceName.WorkspaceFactoryProgID = esriCore.shapefileworkspacefactory.1"
pOutDatasetName.WorkspaceName = pWorkspaceName
pFeatureClassName.FeatureType = ESRI.ArcGIS.Geodatabase.esriFeatureType.esriFTSimple
pFeatureClassName.ShapeType = ESRI.ArcGIS.Geometry.esriGeometryType.esriGeometryAny
pFeatureClassName.ShapeFieldName = "Shape"
pExportOp = New ESRI.ArcGIS.GeoDatabaseUI.ExportOperation
pExportOp.ExportFeatureClass(pInDsName, pQFilter, pSelSet, Nothing, pOutDatasetName, 0)
Else
Exit Sub
End If
