Hi!We are using Survey123 for a land survey and we map out different areas. It would be very useful to see different shapes in different colours in the same map view at the same time. We can only see on at the time right now. Is there a way to see multiple shapes in the same view?Thank you
Hi. If you configure your survey map to display a web map, you will be able to see features as they get added. Will that work for you?
Would the shapes in the web maps be stored and viewed per instance of survey, or on a accessed on a survey wide basis?
