I know for a while if a web map layer was to contain the link to open and push over information to a Survey123 form the questions in the Survey123 form had to be not a in a group. Is that still true? If not how do I get the web map layer to push information to a grouped question and/or a page in Survey123?
Hi @DavidBuehler there shouldn't be an issue passing values to a question inside a group; however, you cannot pass a value to a question inside a repeat.
You can pass values to questions inside groups (or pages) using the same field:fieldname={value} syntax that you would use for a question outside of a group.
Please see this documentation for more info on URL scheme and parameters.
Hope this helps,
Jim
