I have noted that quick report ver. 4.4 is failing to load default values located within my geodatabase. I have specified default values in my geodatabase created in ArcGIS Pro that are not loading in the attributes page of my quick report. Is this an error? or is there an easy fix to this issue that I am missing?
Thank you,
Dustin
Hi @ErwinSoekianto,
I wanted to check-in to see if you have had a chance to look into this issue? I have also filed a request with technical support, so they should also be contacting you eventually.
I hope you and your team have had a Merry Christmas.
The feature layer can be accessed using the following link: https://services1.arcgis.com/JXBurs0uwQlwOiHt/arcgis/rest/services/Nesting_Test/FeatureServer
Turtle Gender is the field where the default is located and should be set to "Female". Please let me know if I should log this as a bug so I can log it right away.
@DustinBaumbach1
Can you share the feature layer so that we can troubleshoot? Maybe something like this is best to work Esri Technical Support, so that we can troubleshoot and log a bug if that is the case.
Erwin.
