Within the Traverse window only Chord and Tangent are option for curve entry. The common curve entry method in a modern plan in Canada is a Radial Bearing. This means every curve entry would need to add the exception code for every line which would slow down the traverse entry. Currently ArcMap Fabrics support all three options Pro should support all three as a default as well.
Thanks Sean.
This is now in the product plan.
We might get in touch for additional clarifications if needed.
Implemented in ArcGIS Pro 2.8.
See Ideas in ArcGIS Pro 2.8 and (1:09) in the video.
Connectez-vous pour publier, suivre du contenu, et plus encore. Nouveau ici ? Inscrivez-vous gratuitement.
