I am trying to calculate geometry for a set of polygons and find their area. At first I was getting an error that said "Failed to apply changes after updating the row with objectID=0 with the calculated value" and it would only give me 5 areas out of 39. Then I hit start editing and tried again and this time values populate but it wont let me save them due to a row error. Any guidance is appreciated because I don't know what could be wrong with my rows.
same here in Pro 3.5.4 and 3.6.0...
(Trying to update 3D Length in ArcGIS Indoors Transitions)
HI. Did you get this issue resolved? I'm getting the same error message when running the "calculateGeometry" tool from ArcGIS Pro. 3.5.1.
Can anyone help me with this error? I'm on ArcPro 2.9
Traceback (most recent call last):File "c:\arcpro\Resources\ArcToolbox\scripts\calculategeometry.py", line 276, in <module>CalculateGeometry(fc, properties, lUnit, aUnit, cs, cformat)File "c:\arcpro\Resources\ArcToolbox\scripts\calculategeometry.py", line 125, in CalculateGeometryucur.updateRow(row)SystemError: <method 'updateRow' of 'da.UpdateCursor' objects> returned NULL without setting an error
Try your calculate geometry outside of your edit session.
You should run a Repair Geometry tool when you are done editing and before any calculations as well
