I need to get the path to the currently open map document for a C# Add-In.While searching, I found several references that use essentially the following:
public string GetActiveDocumentPath(IApplication application)
// The active document is always the last template
ITemplates templates = application.Templates;
return templates.get_Item(templates.Count - 1);
called with:
string mxdPath = GetActiveDocumentPath(ArcMap.Application);
Then I found IDocumentInfo2.Path in the documentation, and it seems to work fine:
public string GetActiveDocumentPath(IMapDocument mapDocument)
IDocumentInfo2 docInfo = mapDocument as IDocumentInfo2;
return docInfo.Path;
called with:
string mxdPath = GetActiveDocumentFolder(ArcMap.Document as IMapDocument);
My question is if anyone knows of any reasons to use one versus the other.
