I am attempting to prepare script which will be used for script tool. First, I am only interested in selecting features then intend on appending zoom to selected routine to the end of code shown here. Having said that I may not even be using the correct tool (select_analysis) but am unsure of one that allows for selection only. Regardless if I could nail down the syntax I am confident I could switch tools effectively. Could someone suggest a better tool andhelp with debugging.Thanks in advance...
# This script runs the Select tool. The user supplies the input
import arcpy
# Get the input parameters for the Select tool
infeatures = arcpy.GetParameterAsText(0)
userinput = arcpy.GetParameterAsText(1)
# Run the Select tool
arcpy.Select_analysis(infeatures, "NEW_SELECTION", '\Job_Num\" = %s' % userinput)
