I have an app where i need to save the results on a custom array. They come from the deferred identify task when an user clicks on the map.
I have the following:
mapp<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'click'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> identifyTask<SPAN class="punctuation token">,</SPAN> identifyParams<SPAN class="punctuation token">;</SPAN>
identifyTask <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyTask</SPAN><SPAN class="punctuation token">(</SPAN>layers<SPAN class="punctuation token">.</SPAN><SPAN class="token function">read_dynamic_ap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">IdentifyParameters</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>tolerance <SPAN class="operator token">=</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>returnGeometry <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>layerIds <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>layerOption <SPAN class="operator token">=</SPAN> IdentifyParameters<SPAN class="punctuation token">.</SPAN>LAYER_OPTION_ALL<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>width <SPAN class="operator token">=</SPAN> mapp<SPAN class="punctuation token">.</SPAN>width<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>height <SPAN class="operator token">=</SPAN> mapp<SPAN class="punctuation token">.</SPAN>height<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>geometry <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">;</SPAN>
identifyParams<SPAN class="punctuation token">.</SPAN>mapExtent <SPAN class="operator token">=</SPAN> mapp<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> deferred <SPAN class="operator token">=</SPAN> identifyTask
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">execute</SPAN><SPAN class="punctuation token">(</SPAN>identifyParams<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addCallback</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> arrayUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> feature <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>feature<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> layerName <SPAN class="operator token">=</SPAN> result<SPAN class="punctuation token">.</SPAN>layerName<SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>layerName <SPAN class="operator token">=</SPAN> layerName<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>layerName <SPAN class="operator token">===</SPAN> <SPAN class="string token">'Cars'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> carsTemplate<SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"ID: ${id}"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Car: ${car} <br />"</SPAN> <SPAN class="operator token">+</SPAN>
<SPAN class="string token">"Type: ${type}<br /> "</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setInfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN>carsTemplate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapp<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setFeatures</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>deferred<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
mapp<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">.</SPAN><SPAN class="token function">show</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//see content :</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"hello def"</SPAN><SPAN class="punctuation token">,</SPAN> deferred<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>In the same point could be more than 1 result, so i want to save them all in a custom array made for me for special purposes.
When i see the content coming for that deferred var i have this:
console.log("hello def", deferred);
Where i can see there is a property called results (its an array).
I tried to put in console.log(deferred.results) but i get undefined.
There is a way how to save those results? What im doing wrong?
Thanks in advice.
