I'm sorry to bother you. Could you help me with some problems in the Network Analyust? Construct a "set of network data" I get, there is also a layer of finished streets. The problem is, I do not know whether the correctly filled streets attribute table. Can you tell what kind of data are needed specifically for that would all rabotalo.Tak same problem in turns. So all I can calculate for pedestrians, but can not set limits for cars. In advance thank you if you can help.
