Hello all,
I'm not sure if it's possible, but we would like to access a private map without login. I'm trying to do that using the API token, but is not working very well. My code is something like:
require([
"esri/views/MapView",
"esri/WebMap",
"esri/config",
"esri/identity/IdentityManager",
"dojo/domReady!"
], function(MapView, WebMap, esriConfig, esriId, domReady){
esriConfig.portalUrl = "https://test.maps.arcgis.com/"
var userToken = //get token from https://www.arcgis.com/sharing/rest/oauth2/token
var token = {
'server': 'https://test.maps.arcgis.com/rest/services',
'token': userToken
esriId.registerToken(token);
var webmap = new WebMap({
portalItem: {
var view = new MapView({
map: webmap,
container: "viewDiv"
But is not working. The map area still blank, like if my map doesn't exists.
Any idea?
Thank you!
