When working on a recent project, I ran across the need to use Coded Domain Values in an InfoTemplate. This is my solution, derived from Search Widget and InfoTemplate, Domains, Subtypes
<SPAN class="keyword token">var</SPAN> subTypeVal<SPAN class="punctuation token">;</SPAN>
getSubtypeDomain <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>fieldVal<SPAN class="punctuation token">,</SPAN> fieldName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">.</SPAN>typeIdField<SPAN class="operator token">!=</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//console.log("Have Subtypes"); </SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>fieldName<SPAN class="operator token">==</SPAN>featureLayer<SPAN class="punctuation token">.</SPAN>typeIdField<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">.</SPAN>types<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>lsf<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>fieldVal<SPAN class="operator token">==</SPAN>lsf<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
fieldVal<SPAN class="operator token">=</SPAN>lsf<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">;</SPAN>
subTypeVal<SPAN class="operator token">=</SPAN>lsf<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>lsf<SPAN class="punctuation token">.</SPAN>id<SPAN class="operator token">==</SPAN>subTypeVal<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>lsf<SPAN class="punctuation token">.</SPAN>domains<SPAN class="punctuation token">[</SPAN>fieldName<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>codedValues<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>domain<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>fieldVal<SPAN class="operator token">==</SPAN>domain<SPAN class="punctuation token">.</SPAN>code<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
fieldVal<SPAN class="operator token">=</SPAN>domain<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">//console.log("No Subtypes"); </SPAN>
subTypeVal<SPAN class="operator token">=</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">;</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>featureLayer<SPAN class="punctuation token">.</SPAN>fields<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>ldf<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>ldf<SPAN class="punctuation token">.</SPAN>name<SPAN class="operator token">==</SPAN>fieldName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>ldf<SPAN class="punctuation token">.</SPAN>domain<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
array<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>ldf<SPAN class="punctuation token">.</SPAN>domain<SPAN class="punctuation token">.</SPAN>codedValues<SPAN class="punctuation token">,</SPAN> lang<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>domain<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> fieldVal<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> infoContent <SPAN class="operator token">=</SPAN> <SPAN class="string token">"<strong>Attribute</strong>: ${Attribute:getSubtypeDomain}"</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> infoTemplate <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">InfoTemplate</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Title"</SPAN><SPAN class="punctuation token">,</SPAN> infoContent<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> featureLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>"<SPAN class="comment token">//you/services/url",{</SPAN>
infoTemplate<SPAN class="punctuation token">:</SPAN> infoTemplate<SPAN class="punctuation token">,</SPAN>
outFields<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"*"</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
