I have some feature classes in SCOTT schema and created two versions (1) QA (2) TEST on sde.default. Then registered some feature classes as versioned and editing is carried out on two versions. The edits are reconciled in favour of edit version.
(Q1) I got warning message that version is protected when edits are posted, Do I need to enable the sde.default version as public to post edits ?
(Q2) There are delta tables (add/delete) in SCOTT schema and contains edits. Whether these delta tables are removed automatically if i delete versions ?
(Q3) There are records in states and state_lineages tables. Whether these records are removed automatically if i delete versions ?
