Code formatting tips
Updated - 2017/06/27 Added another reference and some editing.
This topic has been covered by others as well...
We all agree the Geonet code editor is horrible... but it has been updated.
Here are some other tips.
To begin... introduction or review
- don't try to post code while you are responding to a thread in your inbox
- access the More button, from the main thread's title... to do this:
- click on the main thread's title
- now you should see it... you may proceed
| Step 1... select ... More ... then ... Syntax highlighter |
- Go to the question and press Reply ...
- Select the Advanced editor if needed (or ...), then select
If you can't see it, you didn't select it More...Syntax highlighter ,
Your code can now be pasted in and highlighted with the language of your choice ......... Your code should be highlighted something like this ............ --- Python ----------------------------- <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
a <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Sample results:... {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>-------------------------------------------- Now the above example gives you the language syntax highlighting that you are familiar with.. Alternatives include just using the HTML/XML option -----HTML/XML --------------------- # just use the HTML/XML option.. syntax colors will be removed
import numpy as np
a = np.arange(5)
print("simple format style {}".format(a))
simple format style [0 1 2 3 4]<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>-------------------------------------------- <SPAN class="line-numbers-rows"></SPAN>NOTE: you can only edit code within this box and not from outside! |
| Script editing tips | cont'd |
HTML editing tips:.... - You can get into the html editor for fine-tuning, but it can get ugly for the uninitiated.
- Comments get deleted ... this not a full editor under your control
- If you have lots of text to enter, do it first then enter and format code
- If editing refresh is slow, use the HTML editor or you will have retired before it completes.
| - The editor seems to edit each character as you type and it gets painfully slower as the post gets bigger.
- You can improve comments and code output by using tables like this and in the example below.
Here is a simple script with code and results published in columns (2 columns * 1 row). If the contents are wider than the screen, the scroll-bar will be located at the end of the document rather than attached to each table (except for iThingys, then just use swipe).
| Sample script using a plain format... 1920x1080px screen size | Result 2 |
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> a <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN><SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Sample results:... {}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="comment token"># really long comment 30 |------40 | -----50 | -----60 | -----70 | ---- 80|</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN> | Sample results<SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="number token">2</SPAN> <SPAN class="number token">3</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="operator token">>></SPAN><SPAN class="operator token">></SPAN> <SPAN class="comment token"># really long comment 30 |------40 | -----50 | -----60 | -----70 | ---- 80|</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN> |
Leave space after a table so you can continue editing after the initial code insertion.
It is often hard to select the whitespace before or after a table and you may need to go to the html editor < > just above the More toggle
| Larger script sample... |
Before code tip: try to keep your line length <70 characters <SPAN class="comment token"># -*- coding: UTF-8 -*-</SPAN>
<SPAN class="string token">"""
:Script: demo.py
<SPAN>:Author: </SPAN><A class="jive-link-email-small" href="mailto:Dan.Patterson@carleton.ca" rel="nofollow noopener noreferrer" target="_blank">Dan.Patterson@carleton.ca</A>
:Modified: 2016-08-14
:Purpose: none
:Functions: help(<function name>) for help
: _demo - This function ...
:Notes:
:References
"""</SPAN>
<SPAN class="comment token">#---- imports, formats, constants ----</SPAN>
<SPAN class="keyword token">import</SPAN> sys
<SPAN class="keyword token">from</SPAN> textwrap <SPAN class="keyword token">import</SPAN> dedent
ft <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">'bool'</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">lambda</SPAN> x<SPAN class="punctuation token">:</SPAN> repr<SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">.</SPAN>astype<SPAN class="punctuation token">(</SPAN><SPAN class="string token">'int32'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'float'</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'{: 0.3f}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">}</SPAN>
np<SPAN class="punctuation token">.</SPAN>set_printoptions<SPAN class="punctuation token">(</SPAN>edgeitems<SPAN class="operator token">=</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> linewidth<SPAN class="operator token">=</SPAN><SPAN class="number token">80</SPAN><SPAN class="punctuation token">,</SPAN> precision<SPAN class="operator token">=</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> suppress<SPAN class="operator token">=</SPAN><SPAN class="token boolean">True</SPAN><SPAN class="punctuation token">,</SPAN>
threshold<SPAN class="operator token">=</SPAN><SPAN class="number token">100</SPAN><SPAN class="punctuation token">,</SPAN> formatter<SPAN class="operator token">=</SPAN>ft<SPAN class="punctuation token">)</SPAN>
script <SPAN class="operator token">=</SPAN> sys<SPAN class="punctuation token">.</SPAN>argv<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token">#---- functions ----</SPAN>
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">_demo</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
:Requires:
:Returns:
"""</SPAN>
<SPAN class="keyword token">return</SPAN> None
<SPAN class="comment token">#----------------------</SPAN>
<SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">"__main__"</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"""Main section... """</SPAN>
<SPAN class="comment token">#print("Script... {}".format(script))</SPAN>
_demo<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Some space for editing after should be left since positioning the cursor is difficult after the fact. |
Output options - You can paste text and graphics with a table column.
- You can format a column to a maximum pixel size.
Sample output with a graph Option 0: 1000 points [[ 2. 2.] [ 3. 3.]] extents .... snip Time results: 1.280e-05 s, for 1000 repeats point_in_polygon.png
So there has been some improvement.
Again...
You just have to remember that to edit code...
you have to go back to the syntax highlighter.
You can't edit directly on the page.
