I have been attempting to get into Python multiprocessing. Just a warning, it's not for the faint of heart. It's great when it works, but there are many gotchas! Here's some background on that if you want to read up:
If your python script tool uses parallel processing, you may want your tool to recognize a new environment setting recently added to ArcGIS: parallelProcessingFactor:
Parallel Processing Factor (Environment setting)—Help | ArcGIS for Desktop
from the help article:
The value of this environment determines the number of processes across which a tool spreads its operation. Those processes will be divided between hardware cores (processors) built into the machine. The number of hardware cores does not change based on this setting. |
Here's a function that will convert this setting to the number of cpus argument used for multiprocessing.Pool()
UPDATE: now supports 0 - this value can be used to signal your script that no multiprocessing should take place. Also I added better exception handling.
def arcpy_cpus(default=None):
"""Determine number of CPUs to use with Python multiprocessing.Pool()
based on arcpy.env.parallelProcessingFactor.
import multiprocessing
import arcpy
ppf = arcpy.env.parallelProcessingFactor
if ppf in ["", None]:
if default in ["", None]:
ppf = multiprocessing.cpu_count() - 1
else:
ppf = default
if str(ppf) == "0":
cpus = 0 # no multiprocessing
try:
if '%' in str(ppf):
pct = float(ppf.replace("%",""))
cpus = int(multiprocessing.cpu_count() * (pct / 100.0))
else:
cpus = int(ppf)
if cpus < 0:
raise
except Exception as msg:
raise Exception("Invalid parallelProcessingFactor \"{}\"".format(ppf))
return cpusHere are some test runs of this function, so you can see what it returns with different parameters:
print("{:8} {:5} {:5}".format("env", "def=\"\"", "def=2"))
for k in ["0", "1", "", None, "1%", "2%", "50%", "100%", "200%"]:
env.parallelProcessingFactor = k
print ("{!r:8} {:5} {:5}".format(k, arcpy_cpus(), arcpy_cpus(2)))
env def="" def=2
'0' 0 0
'1' 1 1
'' 7 2
None 7 2
'1%' 0 0
'2%' 0 0
'50%' 4 4
'100%' 8 8
'200%' 16 16
