I have a DWG with a WLD file that will place the data properly for me when I define the appropiate projection in ArcGIS Pro. However, the CAD desinger has added an object data table that is not visible when I read the DWG in ArcGIS Pro. The object data table will export to the attribute table of a SHP file from AutoCAD, however, the drawing is not georefernced and I don't know how to georefernce the SHP file.
I was hoping that the CAD designer could use the plugin to georefernce the DWG in AutoCAD and the resultant exported SHP would be georeferenced. Is this easy to do? Can they use the coordinates from the WLD file?
