I use ArcSDE 10.2 with Oracle 11g and I use ST_Geometry as the default GEOMETRY_STORAGE.
I work in .NET Framework and I use the Oracle Developer Tools (ODT) to create a wrapper for the User Defined-Type (UDT) ST_Geometry. I can read the whole object structure but I don't know how to interpret the binary stream stored in the POINTS property of the ST_GEOMETRY object.
With refer to: ArcGIS Help 10.1, ESRI says that:
"Points: Contains the byte stream of the point coordinates that define the geometry" but no further detail is given.
Is there any documentation about that or anyone knows how to interpret the POINTS property?
Thanks in advance
Andrea
