Has anyone have any experience using Knockout with Web AppBuilder? I manage to incorporate it into a custom widget and it works well. However, I ran into issue when applying Knockout for multiple custom widgets. Knockout is giving me the following error.
Error: You cannot apply bindings multiple times to the same element.
Although I am applying binding by using ko.applyBindings(VM, Element) with element being the container div of my custom widget. For some reason, it looks like the second parameter is being ignored. I embed most of my code in the startup routine of each widget. My goal is to using Knockout either with one viewmodel applied to the entire application (I don't know where to put this code) or multiple viewmodel bind to different elements (that doesn't seem to work either). Hopefully, someone can offer some advice on what is proper way to implement Knockout in the Web AppBuilder. Or using
